Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › SEIMANS FF KG34NX90GB
- This topic has 6 replies, 4 voices, and was last updated 15 years, 9 months ago by
funkyboogy.
June 17, 2010 at 9:04 pm #55312
funkyboogy
Participanttrying to get into freezer evap fan , what a pig
i removed 2 crews at top but evap unit will not budge ..does anyone know how to get into these things ..
cheers ally
June 18, 2010 at 7:52 am #323046funkyboogy
ParticipantRe: SEIMANS FF KG34NX90GB
anyone ?
im going back today ..
please dont want to break this ff
June 18, 2010 at 10:52 am #323047superfix
It needs a 48 hour defrost, then the repair kit fitting to it.
June 18, 2010 at 11:32 am #323048funkyboogy
cheers what the repair kit ??
f/f was running ok but fan blade sounded as though it was hiting something
ally
June 18, 2010 at 12:39 pm #323049nomadPaul
ParticipantTh way the evaporator sits means that if it ices over , it practically glues itself to the lower cover and is a bugger to remove. If its given a real good defrosting then the cover will slide forward quite nicely. Just remember that there is a defrost heater on the cover and the connector will need to be unplugged from the rear wall connector prior to pulling the cover completely away .
If this is an older model , Pre-mid 2007 , then it may need the evaporator cover plate fitting and a new module . These were the 2 main components that needed replacing for the main modification that these applainces had early doors.
June 18, 2010 at 4:26 pm #323050funkyboogy
cheers .. went back today ..
as you said evap assy came forward no probs … uncliped defo wires
fan unit had slipped forward so i pushed it back dropped a bit of super glue on end of shaft , hopefully that will do it ..
advise cust may need mod kit if fault re-occurs ..
quite easy in the end … after defo
June 4, 2013 at 8:44 pm #323051RocketMan
I know it’s an old thread but I’ve got one of these to look at. It’s an earlier 06 model. What’s the mod kit for? Any details please? This one sounds like a fan/over icing fault.
If this is an older model , Pre-mid 2007 , then it may need the evaporator cover plate fitting and a new module These were the 2 main components that needed replacing for the main modification that these applainces had early doors.
