Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Seimens Intergrated FF
- This topic has 5 replies, 3 voices, and was last updated 16 years, 4 months ago by
subs.
November 26, 2009 at 9:48 am #50475
subs
ParticipantENR K130M443GB/03 FD8402
When i looked at this fridge the led that lights up on each tempreture number you select will flash 12 times. I could hear the motor kicking in then cutting out. When i checked out the compressor it was duff. Any one know why this unit has two capacitors for the motor, one very large looking one 420-470v 4uf and one smaller 420-470v 2uf.
What does the 12 flashes mean? Although the motor is buggered it was the control board that was cutting the power to the motor when it would not start, not the motors overload protector. Going to fit new motor but not sure about module.Anyone?
Subs
November 26, 2009 at 10:06 am #304926subs
ParticipantRe: Seimens Intergrated FF
Just thought….it must be one start one run capacitor!
Just looks like a bog standard compressor from singapore to me.Subs
November 26, 2009 at 12:32 pm #304927pup
subs wrote:Just thought….it must be one start one run capacitor!
on seimens 😆November 30, 2009 at 12:03 am #304928subs
Any one know if 12 flashes is a fault code?
Subs
December 3, 2009 at 8:39 pm #304929subs
Fitted new compressor to this FF but as i suspected there is still a problem with either sensor or more likely control board. When you turn it on it will run for a while, sometimes 2-3 minutes or so and then cut out. If you turn it off and on again it will try to power up the compressor but cut the power to the compressor after a couple of seconds. Its as though a relay on the board or something is breaking down. Compressor i fitted is fine because ive by-pasted the control and it runs fine.
Are thes boards prone to fail?
Could it be the ntc? There is one in the fridge but i think there may be one foamed in.
Come on you Bosch/ Seimens guys, help me out here please!
SubsDecember 3, 2009 at 11:02 pm #304930whitevanman
subs,
I seem to think theres a mod/kit available for the Ntc as its foamed in, and am almost positive this particular topic was discussed 2-3 years ago on ukwg
somthing on the lines of this
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=27930&highlight=siemens+fridge+freezer+mod -
