Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Seimens KT18RP90 larder fridge.
- This topic has 4 replies, 2 voices, and was last updated 9 years, 6 months ago by
KPbikefix.
October 10, 2016 at 10:26 pm #89550
KPbikefix
ParticipantHello all
I’m hoping that someone may help to diagnose this problem.
This fridge was made about 2009 and has worked well until now.
Today I noticed the temperature control indicator was slowly flashing on and off with a buzzing noise each time the indicator light dimmed. This noise was coming from the compressor unit. The comp unit was hot at this point so I switched off and let it cool for a few hours. The fault continued when switched on again, but with much longer time between buzzes. The compressor does not seem to run.
My first thought was that the comp unit is dead, but I don’t know whether it could just be a start relay or capacitor problem.
If the comp is gone then I guess it is time for a new fridge.
The comp unit is a Danfoss TLY4KK.2
Thanks in advance for any suggestions.October 10, 2016 at 11:22 pm #441699electrofix
ModeratorRe: Seimens KT18RP90 larder fridge.
sound like it may be a control board problem
October 29, 2016 at 1:26 pm #441700KPbikefix
ParticipantRe: Seimens KT18RP90 larder fridge.
Hi Dave and thanks for the reply.
Sorry not to acknowledge sooner but this fault occurred the day before I was away for a while. Fortunately the fridge was all but empty at that point.
I have tried to run the fridge again twice since getting back,and it starts and runs normally until the set temperature is reached , at which point the fault recurrs. I’m hoping this rules out the compressor as the issue. Does this lend weight to your initial thought of a control board fault?
Thanks again.
Keith.October 29, 2016 at 2:54 pm #441701electrofix
its hard to say but yes sort of. it sounds loke a board power supply problem. ie it has not got enough power to supply all the components and the board crashes, then recovers. hence the flashing
some boards can be repaired and look up QER and see if they can check your board
dave
November 25, 2016 at 8:15 pm #441702KPbikefix
Hi Dave
Once again sorry for such a late reply.
Just to let you know that your diagnosis was 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} correct – new board installed and the fridge is working perfectly , so thanks again.
Regards
Keith. -
