select 610 by diplomat
Home Forums Public Support Forums Help And Support Cooker And Oven Forum select 610 by diplomat
Viewing 15 posts - 1 through 15 (of 19 total)
  • #5757
    Does anyone know where I can get a user manual for a select 610 by diplomat cooker? The previous owners never left any when they moved!
    #113516
    Dave_Conway
    Re: select 610 by diplomat
    Could you find the full model number from the rating plate please. It should be around the door somewhere, failing that on the top of the oven itself.
    The model will begin with APM/APL/AHY or similar
    Thanks.
    #113517
    I’ve looked everywhere and can’t find one! It is a built in oven so cant get to the top. The only APL No I can find is for the microwave housing on top. The only markings of any kind on the oven state Select 610 by Diplomat.
    #113518
    It should be on the rating plate, normally on the inside leading edge of the oven cavity when you drop the door down. If it’s been removed then you may well be out of luck. 🙁
    Hi Guest,
    did you get an answer ? I need one as well – I’m in exactly the same situation.
    Cheers
    Sid
    #113520
    Dave_Conway
    I don’t think he did Sid.
    So, to help narrow the odds down for you both if you can’t find the model number, let me know the following please:
    Built in or free standing
    Double or single oven
    Gas, electric or dual fuel
    Approximate age
    I’ll see what I can come up with if you supply all of the above.
    Regards.
    #113521
    OK it’s a single electric oven. It is built in with an electric hob (also by diplomat) on top. Don’t know how old but I would guess at 5yrs. Whereabouts would I find this ID code to help you ?
    Cheers
    Sid
    #113522
    Dave_Conway
    The model number is normally round the door somewhere as desribed, but for this one it may be on the roof of the oven.
    No matter, I have found it I think, just need to confirm a couple of things…….
    The oven should have 2 knobs on the left and a clock/timer on the right with didgital display and three buttons.
    #113523
    No sorry Dave,
    It’s got one knob on the left going through to 250 deg and Grill and an analogure display clock on the right with black knobs to control the On and Off I think (that’s one of the things I want to learn from the User Manual).
    Cheers
    Sid
    #113524
    Dave_Conway
    Wierd all the Diplomat 610 versions on the tech disk have two knobs and an electronic timer.
    In that case, you’ll need to slide the oven out of the housing and get the model number off the top of the oven itself.
    Let me know when you find it.
    #113525
    I too have a select 610 by diplomat. I pulled the housing out and on the top it says hygena AHY3300 – maybe this will help the others too.
    I also am after the manual because my oven doesnt work and have been told that should be the clock setting.
    #113526
    Name : Diplomat Turbo Single Electric Oven
    SKU : AHY3300
    Colour : Stainless Steel
    Delivery Within : 1 Week
    General Description
    Fan oven
    Interior light
    Full Fixed grill
    Safer touch door
    Programmable timer/clock
    Oven Capacity – 56 litres
    Energy Rating – B
    Fuse Rating – 13 amp
    Connected Load – 2.07 kw
    Catalytic liner set available (AHY3951)
    Dimensions – H 597mm, W 597mm, D 560mm
    THIS IS ALSO WHAT I FOUND WHILE SURFING – HOPE IT HELPS 😀
    #113527
    FORGOT TO SAY FOUND IT ON THE MFI WEBSITE.
    #113528
    Dave_Conway
    That’s the one 😀
    If you phone MFI extracare on (08457) 959722 and go through to the spares dept which is option 4 I believe and ask for part number OIFUD That is the user manual for the AHY3300
    Regards.
    #113529
    thanks you are a life saver 😉
