Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Selector indicator broken on Neff U1552 Oven
- This topic has 5 replies, 4 voices, and was last updated 16 years, 7 months ago by
bigjohn.
August 30, 2009 at 9:04 am #48180
bigjohn
ParticipantThe stencil that rotates above the control knob of the fan oven has broken. The oven control knob operates the oven but we have to “guess” what temperature we have set the oven at.
Do I have to buy the whole top oven control assembly or can just the small window containing the rotating stencil be obtained as a spare part?
Where is the best place to buy such a part?August 30, 2009 at 9:20 am #295874Penguin45
ParticipantRe: Selector indicator broken on Neff U1552 Oven
If you pop onto http://www.bshappliancecare.com , click on NEFF and spare parts, you can enter your model details and have a look at the exploded diagrams of your machine. Looks like all the components are available individually, so shouldn’t dent the wallet too badly.
August 30, 2009 at 6:47 pm #295875bigjohn
Thanks Penguin 45
It seems I can order just the part I need. If I get stuck when trying to fit the new component into the main switch I may be back on for more help!
bigjohn
August 30, 2009 at 9:17 pm #295876eastlmark
ModeratorRe: Selector indicator broken on Neff U1552 Oven
good old Film strip, not cheap and an absolute swine to fit. would advise getting this job done by a pro. Also, take care you order the correct one as, if its a double oven, there are 4 fitted and they are all different. Not only that, if one has snapped the others may soon follow suite.
September 2, 2009 at 7:58 pm #295877bigjohn
Thanks for the warning eastlmark.
Incidently, where did you get that fly that crawls across your replies!!!
August 20, 2012 at 9:42 am #295878BigBadDad
Came across this when I was looking at my own old posts (I have the same oven) and thought I’d post a reply.
I’m now pretty sure that I’ve replaced all four film strips at least once, and I’ve come to the point where I resent the poor design and the cost, so I’ve come up with a low-tech solution.
Last time I replaced a film strip, I made two paper templates with holes for the control knobs, and marked all of the temperatures on them. Two film strips have recently snapped, and I’m going to use Letraset numbers to mark the temperatures around the outside instead. It’s too early to say if it will be a good solution for the long-term, but I’d rather do this than pay the extortionate prices for the film strips.
Hope that helps
BBD -
