Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Sensor dry integrated dryer
- This topic has 8 replies, 3 voices, and was last updated 6 years, 4 months ago by
Esha911.
December 2, 2019 at 3:41 pm #96822
Esha911
ParticipantMy sensor dry dual heat model diplomat apm8620 won’t heat I’ve trued reset button worked a few times then heated up to much now it comes in drum turns but blows cold air please help with this.
December 2, 2019 at 7:09 pm #464936Specialist01269
ParticipantCould be one of a number of things, do you have a Multimeter and know how to use it ?.
December 2, 2019 at 8:24 pm #464937Esha911
ParticipantI’m sorry I don’t know what a multimeter is
December 2, 2019 at 9:04 pm #464938electrofix
Moderatorwell unless you can test components you cannot find the faulty one
December 2, 2019 at 9:37 pm #464939Specialist01269
ParticipantAs Dave says, you need to be able to test parts to see if they are working. A Multimeter is the piece of Equipment used to do this, you need to have a Multimeter and be able to use it to carry out any fault finding. Please call a local repairer to look at your appliance.
December 2, 2019 at 9:50 pm #464940Esha911
ParticipantI didn’t really want to pay to much I was hoping to solve the issue, so firstly the dryer stopped giving hot air so pulled it out and reset it then it was kk then it tripped again reset it again then it was drying the clothes but really over heating like burning smell then got someone to undo vent hose there was some fluff removed that all seemed fine then on Sunday I put clothes in starting blowing cold air pulled it out again but this time nothing worked not the reset button or anything drum turn but is blowing cold air. I really appreciate your help thanks.
December 2, 2019 at 10:09 pm #464941Specialist01269
ParticipantSorry but we can’t help you unless your able to test parts, without this ability your just playing guess and we don’t do that. You would just be swapping parts on the off chance that you hit the right part, this is a really bad and expensive way to do things.
December 2, 2019 at 11:07 pm #464942Esha911
ParticipantKk so what do I need to do you advise me thanks
December 2, 2019 at 11:20 pm #464943Specialist01269
ParticipantHi: You really need to call a local appliance repairer to look at your machine. If you look at our find an engineer section, there may be someone in your area.
