sensor ribs on BEKO drcs68w >???
Home Forums Public Support Forums Help And Support Washing Machine Help Forum sensor ribs on BEKO drcs68w >???
  • #34312
    audi1978
    hello all hope all is well. my dryer spins round but no heat ! have checked all areas, filter, tank etc and all is clear and clean.checked manual and says to clean SENSOR RIBS but nowhere does it show where these ARE? have checked the website but no joy and tried googling but no luck either. does anyone know where the sensor ribs are please ?
    #242129
    helo_75
    i would think they mean the drum paddles
    but that wont stop it heating
    theres a heater cut out over the heater, thats more likely to be the problem
    plug out if your checking!!!
    #242130
    WhirlpoolQueen
    Re: sensor ribs on BEKO drcs68w >???
    The sensor rib is the little rectangular stainless steel grid bit in the drum just behind the filter in the front of the door aperture. – WQ
    #242131
    audi1978
    thanks for the advice !
    #242132
    audi1978
    no stil no joy have rung out to be checked as is still under warranty and dont fancy messin about. thanks fro al your help though
    #242133
    andy_from_ireland
    sorry for resurrecting old thread but in these tumble drier there is also a sensor at the top of the drum. You have to take lid off and front fascia control panel off to get to the sensor. If there is open circuit / no resistance across the 2 spade terminals then there will be no heat. Some of these sensors have a red ‘reset’ button on them – others you just have to replace the whole sensor, shouldn’t cost too much.
