Re: Serivs fridge freezer not working after house move
If the compressor runs for a split second and then cuts out it will be the internal overload device cuting off the supply in the compressor.It could be the relay start device which sits on the side of the motor in a plastic box,maybe worth trying a new one.
Something inside the compressor may have got jarred or been weak already and the moving it was the final straw.
Hermetically sealed so you can’t access to do any thing it’s a compressor change which starts at b £170 ish.
Always switch off before investigating.
BG
