Service fridge M0330S
  • #20725
    tintin
    I have got problems with the above fridge.Can’t seem to work out what the problem is.It is frost free and the freezer is working fine,fan in the freezer is also working fine.Changed the electronic module that is on the top behind the facia panel.Any clues,please help.
    Thanks so long.
    Tin Tin
    #188169
    tintin
    Re: Service fridge M0330S
    Sorry didn’t add the problem,fridge not cooling.
    #188170
    Washman
    Whats the problem , fridge temperature is controled by an air flow control thermostat inside fridge compartment , is this working. And is freezer evaporator clear of ice
    Mike
    #188171
    tintin
    Yes the control thermostat is working and the evaporator is clear of ice.It was a strange one,when I got there I took the panel in the freezer of to see if everything was clear,I also took the control thermostat of afer words to check that.Then I placed a magnit on the door closed sensor and there was no cold air,I then turned the temp up to 5 and placed the magnit back and there was cold air coming through,left it for 5 mins and placed the magnit back and there was no cold air again.That is what made me think taht it is the module.
    Tin Tin
