SERVICE M6006 WASHING MACHINE
Home Forums Public Support Forums Help And Support Washing Machine Help Forum SERVICE M6006 WASHING MACHINE
  • #36948
    SANDRA46
    :rolls: CAN ANYBODY HELP ME , I`VE CHANGED THE CIRCUIT BOARD ON MY SERVICE M6006 1600 MPR WASHING MACHINE AND NOW I FIND THAT YOU HAVE TO DO A SECRET COMBINATION OF MOVES WITH THE DIAL TO RE-SET THE MACHINE …… 😥 PLEASE DOES ANYBODY KNOW THEM … I`M DESPERATE .I SIT HERE TYPING THIS IN YESTERDAYS KNICKERS, TURNED INSIDE OUT 😳 AINT GOT NOTHING FOR TOMORROW :rolls:
    #252899
    Re: SERVICE M6006 WASHING MACHINE
    Should be plug and play, Sandra – no re-set procedure as far as I’m aware. Where did that info come from?
    SANDRA46
    INITIALY ALL THE FOUR FRONT LIGHTS ON THE MACHINE WERE FLICKERING , MACHINE NOT WORKING , THEN WHEN I OPENED THE TOP THE CIRCUIT BOARD HAD BURNED OUT , REPLACED THIS PART , NOW LIGHTS ARE ON SOLID , AND THE MACHINE IS STILL NOT WORKING ( BEFORE WHEN I HAD AN ENGINEER OUT, HE FLICKED THE DIALS IN SOME SORT OF ORDER , THEN SAID , ” ITS O.K. NOW I`VE RESET IT …… AND CHARGED ME ??????????
    #252901
    No. I suspect you have been misled……
    After the repairers visit, did the machine work at all? The electronics are notiously unrelable on these, but even so, you should have some sort of warranty on the repair. Was the engineer a Servis agent, or was this a repair through an independent?
    I realise this isn’t going to immediately solve the, er, foundation garment problem, but I suspect that you have some sort of redress here.
    Dales-Electronic
    Just to make life interesting there are three different boards listed for this machine. Can you let me have the serial number for the appliance which is on a label in the drain filter flap
    #252903
    Washman
    This machine may have the new type Janus module which has to be configered with the Janus Palm unit.
    Serial number required for correct module.
    Mike
    #252904
    SANDRA46
    APPARENTLY THIS MACHINE UPDATED ITS CIRCUIT MODULE , SO I HAD TO WAIT AN EXTRA WEEK UNTILL MY CORRECT MODULE COULD BE SENT TO ME …. THE ONLY DIFFERENCE TO THE MODULE THAT ARRIVED ,WAS THAT THE NUMBER ON THE FRONT ENDED WITH -02 INSTEAD OF 01 . IT FITTED PERFECT , BUT AS I SAID ALL THE LIGHTS ARE ON , BUT THATS IT ….. SERIAL NUMBER ( NOT MODULE NUMBER ) IS 20042710881-010077204-01 . I REALLY APPRECIATE ANY HELP OFF YOU GUYS X OH THE GUARENTEE IS OUT OF DATE , AND IT HAD BEEN WORKING FINE SINCE THE LAST “REPAIR”
    #252905
    Dales-Electronic
    Correct module is 546071000 if the one fitted is otherwise you have got the wrong one. It is not a Janus machine
    #252906
    SANDRA46
    The module I bought from E-Spares after giving them every number i could find on the machine and circuit board …. it cost me £97-00 . …. i`m hoping to return it, as I think this repair could work out too expensive . seen a hotpoint one in friends catalogue for £249-00 , so going to order that …. but as a woman I must say …. at least I did try … Thank you all for taking the time to answer my call for help , its so nice to know that there are still some gentlemen out there ,willing to help a damsel in distress xxxxxx 😉
    #252907
    Dales-Electronic
    One final post then – look at the ISE range before you buy the Hotpoint 🙂
