service rain wave 1100 easher dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum service rain wave 1100 easher dryer
  • #12997
    sheppy
    HI. I have been given this machine but with no instruction book, could anyone tell me how to use the dryer, as so far I have failed to use it. 😥
    #152589
    Dave_Conway
    Re: service rain wave 1100 easher dryer
    Without the model number I can’t be sure but pushing the 1/2 load button is required to make the dryer work on most of these, as well as setting the time etc… 🙂
    #152590
    sheppy
    Thanks for the reply, still cant get the dryer going 😥 .The model number is M911W
    #152591
    Dave_Conway
    Hmm, it should work. The main timer should be set to one of the drying positions, the dryer timer set to the time required, press the half load button then switch it on 😕
    If you need to order the user manual, the contact details are here:
    http://www.servisuk.co.uk/contact1.htm
    #152592
    sheppy
    Many thanks moved the wash setting to a different stop point, dryer now works 😀 .once again thanks for your help
    #152593
    Dave_Conway
    No probs :tup:
    #152594
    StickyStoo
    Sheppy – please can you let me know exactly what settings you used to get it to work… a friend of mine has just moved into a flat and is having the same problem with figuring out how to use the dryer 🙂
    #152595
    Washman
    This is a 6 year old post so I dought Sheppy is watching this forum .The answer to you question is in post above.
    Washman
