Service washer/dryer M9813 (Dryer problem)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Service washer/dryer M9813 (Dryer problem)
  • #23928
    dave_matt
    I have a service washer/dryer M9813. The electronic Module board (H8.1 type) was blown out so i bought a replacement, fitted it and reset the
    therm. stat. button located at back of machine on top of heater
    exchange unit. Problem is everything works except the dryer. Now the
    funny thing is the heater exchange/heating element works (it gets very
    hot) but when you stop the dryer cycle and open the door the inside is
    only cool and theres a horrid smell. I’ve stripped down the machine
    directly after a dry cycle run and the smaller motor/blower is red
    hot. There is a 4micro farad capacitor which sits next to the motor and
    i’m wondering if this is were my problem is???
    Many thanks.
    #199884
    helo_75
    Re: Service washer/dryer M9813 (Dryer problem)
    nah, its more likely to be blocked with fluff in the condenser, needs airflow to keep the elemst at a safe temperature.. the condenser is the plastic tube from the base of the fan unit to the drum…
    be very careful, lots of sharp edges, and tightly fitted parts
    safety first… it hurts!
    oh, and plug out of course!!
    #199885
    dave_matt
    helo_75 wrote:nah, its more likely to be blocked with fluff in the condenser, needs airflow to keep the elemst at a safe temperature.. the condenser is the plastic tube from the base of the fan unit to the drum…
    Have checked and tested motor and capacitor. Have noticed that the blower which is directly on the back of the drum has its spindle stuck and will not rotate. But to get at and remove this i need to first remove the drum flywheel. I have tried using an allen key (is it conventional when removing allen bolt…anticlockwise??)
    Thanks.
    #199886
    Washman
    You need a new air duct cover P#720256100 comes complete with fan.
    The screws can be a pig to remove and duct needs to be be resealed on reassembly. Also make sure you clean out all fluff.
    Mike
