Home › Forums › Manufacturer/WP/Insurer Specific Forums › ISE Trade Support Forum › ISE Forum (Closed) › Servicing/Diagnostics
- This topic has 14 replies, 4 voices, and was last updated 19 years, 12 months ago by
Martin.
April 13, 2006 at 4:07 pm #17123
ParticipantIs there a service manual/sequence chart/wiring diagram for this machine?
Please can I have a copy if available?
April 13, 2006 at 4:30 pm #173061kwatt
KeymasterRe: Servicing/Diagnostics
Nope, we haven’t got it yet. 😕
That’s the bad news.
The good news is that we are now in direct contact and should be getting online access to all the information, spares, tech, the lot, very soon I hope going on communiques this week.
The problem was they had all this arranged and they have or had access but have not passed all the information along with the login details for the system. This has also caused the delay on the van stocks much to my and Kevin’s annoyance as this was supposed to have been in place months ago.
As soon as we have the info so will everyone else.
All I’ll say is that our displeasure is well known. 😉
April 18, 2006 at 3:51 pm #173062Martin
ParticipantRe: Servicing/Diagnostics
I wonder if you managed to fire an ISE up last weekend Ken? Just to get some clarity as to those LED’s sequence of events etc?
April 18, 2006 at 6:36 pm #173063admin
Martin,
would you like one to play with?
Kevin
April 19, 2006 at 7:25 am #173064Martin
kheath wrote:would you like one to play with?
No thanks Kev 😉
April 19, 2006 at 9:48 am #173065iadom
ModeratorRe: Servicing/Diagnostics
I’ll have it. 🙂
April 19, 2006 at 7:32 pm #173066kwatt
KeymasterSorry Martin, I had to find out for you by testing.
The light sequence goes from Ready to Wash as the machine starts and the door locks to Spin and back to Ready as the door unlocks.
Is that enough or do you want more?
Also, just as a side note the program times are (for once) fairly accurate so far, within 5 minutes of the guidelines in the manual.
April 19, 2006 at 8:44 pm #173067admin
noted Jim, lets see how Martin gets on 1st.
Kevin
April 19, 2006 at 9:42 pm #173068iadom
No problem, I have installed 7, and after the Easter lull have two very strong possibles today. 🙂
I may even have time to sit and watch one of them sooner or later. 😉
April 20, 2006 at 8:02 am #173069Martin
Participantkwatt wrote:Is that enough or do you want more?
That’s fine Ken, at least I am some way forward on that issue, thanks!
Have you any idea about the ‘Pre-wash’ LED’s purpose is in fault diagnosis? The user is told that when that light flashes, to “turn off the tap and call for service”? no mention of turning off the machine as well , just the tap for goodness sake????
Does it flash error codes I wonder?
April 20, 2006 at 8:09 am #173070kwatt
KeymasterNo Martin, we’re awaiting all the service info coming through from the Turks.
April 26, 2006 at 11:49 am #173071Martin
Child Lock activation????
It refers that once the child lock is activated, the “first auxillary function’s LED will be flashing!”——– Do I then assume that the first auxillary LED is in fact the PREWASH light?? Not having a machine 😉 I cannot be sure because it would make sense if only for User Booklet clarification! 😕
April 26, 2006 at 12:13 pm #173072kwatt
KeymasterYou’ll have one soon enough Martin and I don’t know the answer to that myself as I’ve not tried the child lock.
I may have tried it had it been to lock them in it! 😆
April 26, 2006 at 5:44 pm #173073Martin
So many things wrong with the User Booklet I’ve spotted it’s getting ridiculous, but I do need to get clarification from a Sequence Chart at least to correct this. For example trying to re-write the Programme Guide at the moment and not knowing which ‘Options’ are available is a joke.
Prewash, Quickwash and Rinse Plus are incorrectly shown on the diagram. And other options which must be included in the various programmes as a default are simple missing 🙂
There’s no HLCC symbols included either, so I will at least get them up on the chart – eventually when these very loose ends are tied that is 😉
I also need to take a trip to Turkey and give someone a kicking I reckon 👿
April 26, 2006 at 6:28 pm #173074admin
Martin,
John and I are meeting Beko tommorow and by now you will have more info to work with 😉
Do you really need to go to Turkey?????
Take your place in the queue 😆
Kevin -
