Servis
  • #27486
    Go on, what was the old Servis “F2” code?
    gegsy
    Re: Servis
    Brushes? or was that F4 😕
    #214308
    Re: Servis
    4 was brushes… I can remember that one…… :rolls:
    gegsy
    Re: Servis
    Servis Quartz
    F2
    THE MACHNE TAKES TOO LONG TO FILL.
    Customer Action:
    1. Check that the taps are turned on fully.
    2. Check the filler hose – if it is kinked, reposition it to remove the kink and reselect the programme.
    3. It may be that your house water pressure is low. If so, switch off electricity, switch on again and reselect proigramme to continue filling process.
    #214310
    Re: Servis
    Right…………
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=24607
    Off you go then, seeing as I’ve made a prat of myself.
