An older dryer! Does anyone have or know of availability of thermostats/cutouts as fitted to this model. There are two at the rear.
Thanks in advance for any info.
Regards tom
Hi tom, the two stats at the rear should be marked ie; yellow spot – 57deg
blue spot – 40 deg. they also have an overheat stat fitted on top off the heater element case – 110 deg, we have a diag from the old manuals, if you want we could fax it to you.
regards barry.
