This is ancient but still works well except every now and again it leaks water – small pools to a mini flood run across the floor. I’ve cleaned the door seal. The main thing is that it only leaks say once in 5 washes! Ideas are very welcome.
I’m on the point of getting a new dishwasher but it seems a shame as it must be around 12 years old and works well apart from the occasional leaking.
Best regards,
Laurie
if the leak is at the right hand side there is a container which fills with water before it goes into the machine visible if you take the right hand side off that could be where the leak is.
plug out first.
Re: Servis 410 – leaking on RHS every now and again
I found the grey plastic catch tray leading to a black rubber openended pipe where the leaks are running to hit the floor. Door seal looks ok and bottom spray arm is metal and has been cleaned. Leaks reduced in volume but still occur every other run of the machine. Any other things to check out and clean or replace?
