Servis auto 800 M3002W
  • #70005
    Muv
    Hi all
    Just been to this machine,fault is no motor rotation on any setting
    Had a quick look at motor (induction) type
    Removed the connector and checked all wiring
    On the plug of the lead coming from motor, looking from the rear of it, there is at top left a green jumper wire. Problem being that the other end is hanging loose..
    Anyone know where this should be located… And also would this be the cause of the problem ..Or more likely to be the module…
    Any help appreciated
    Here are the ID details
    20012610992
    010077121/01
    28812610
    Not sure of the last line as this was badly worn
    #376713
    Earthed return maybe?
    #376714
    Muv
    Hmmm maybe
    It’s only about 3inches long so must connect to another lead in the block connector…
    The female end of the plug has a similar jumper wire, although its black!
    Could it possibly match up with this?
    Think a schematic would be handy!
    Thanks anyway, Martin
    petalpop
    Re: Servis auto 800 M3002W
    11 year old servis
    if its not the capasitor for the motor its beyond economical repair anyway i would have thought
    #376716
    robbra
    Which module has it got? They failed quite often.
    #376717
    Muv
    Customer decided it was not worth repairing… And is buying a new machine from me
    Many thanks for all contributions
