servis auto m6003
  • #52947
    senseib
    This m/c the on light was lit but it would not start when you pressed the start button. Changed the power module and it worked once, but now will not start again.
    any thoughts ❗
    Brian
    #313812
    deltra
    Re: servis auto m6003
    make sure door interlock is latching properly.
    #313813
    robbra
    Did it “clunk” just after the start button. If not as deltra says try door lock, if it does normally the module. It may have been the lock all along as Servis door always need a nudge after closing. Also loosen the screws on the hinge, lift the door and tighten so the pecker goes into the lock centrally. A dropped door often stops the lock locking.
    Rob
    Let us know what happens.
    #313814
    senseib
    Hi lads, Thanks for your replies.
    I changed the door interlock and adjusted the door but still the same. When i set the programmer to the top piosition (off position) the on light is lit and the start button is also lit, but as soon as i turn the the programme knob to any of the programmes the start button light goes out. It did work once with a recon’ module for emw, but only once.
    Even bought a brand new module thinking it had to be that, but just the same with the new module. Checked the connectors all ok.
    This one has got me beat unless someone else knows the solution 🙁
    Brian.
