If it’s the fan oven then it will just be the fan element that’s gone although, information on that cooker is scarce. But, it’s this fan oven element you need if that’s the case and it’s just a little cheaper than the £66 Servis wanted for one.
kwatt wrote:If it’s the fan oven then it will just be the fan element that’s gone although, information on that cooker is scarce. But, it’s this fan oven element you need if that’s the case and it’s just a little cheaper than the £66 Servis wanted for one.
HTH
ok I will order from the link… is it perfectly visible when taking of the rear panel? and and easy fit? I can find a lot on this.
