servis d/w error code
  • #23815
    hilly
    servis m4608al machine showing e5 (d/w) every time i go to it it works ok (sods law) but customer has had e5 come up a couple of times couldnt find it in error codes section any ideas?
    thanks paul
    #199453
    nationalhomecare
    Re: servis d/w error code
    Hi Paul
    ERROR E5, This check is carried out during the drain water phase.
    1st case. The error DOES NOT stop the wash and is displayed at the end of the wash cycle
    Error is signalled before filling with water if the pressure switch is registering FULL
    Skips water full phase
    Executes the next phase.
    Check the drain pump is operating correctly and hoses are not blocked.
    Check the pressure switch resets correctly
    2nd case. The error STOPS the wash and is displayed IMMEDIATLY.
    As above but is still full of water from last wash or pressure switch is acctivated.
    HTH
    Steve 😉
    #199454
    hilly
    cheers steve will check it out! why cant they keep it simple? 😕
    paul
