Servis door boot Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Servis door boot This topic has 2 replies, 3 voices, and was last updated 19 years, 4 months ago by cornwell40. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts November 22, 2006 at 10:19 am #22779 cornwell40Participant Is it just me or does every Servis door boot squeal when you fit it because it catches the I/drum. 😡 Tony C November 22, 2006 at 1:47 pm #196130 barryfastParticipant Re: Servis door boot hi yes, try pulling the the door boot away from the drum befor you tighten the cilp its worked with me Barryfast November 24, 2006 at 8:56 pm #196131 kevvieParticipant Re: Servis door boot There are two different door boots. One is for a plastic outer tub. The other is for a metal outer tub. The gap between the inner tub and outer tub are different. If the wrong gasket is fitted, one will rub. 😀 Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
