Servis dryer fan not working
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Servis dryer fan not working
  • #22454
    Pidsley
    Does anyone know where the fan is located, can it be easily reaplced, Woul dthere other reasons why it does not blow?
    Anyhelp gratefully received.
    #195025
    Re: Servis dryer fan not working
    Go on – give us a clue…. Model number, please.
    Pidsley
    Re: Servis dryer fan not working SERVIS XXL6
    Sorry model number is SERVIS XXL6
    #195027
    Washman
    Model Number will start with M2
    Mike
    #195028
    Pidsley
    Re: Servis dryer fan not working M9713
    Model number M9173 Help, i have reset kick out switch, but still no fan and rapidly heats up and trips again.
    #195029
    OK, so its a washer dryer……
    With the power off:
    Is the fan motor free to rotate?
    Do you get a resistance reading through the motor when the wires are disconnected? Test meter required.
    Check all around the top of the machine – broken wires are a regular problem with these.
    If the above check out OK, you will have some sort of supply problem to the motor, most likely related to the control circuitry – time to send for the pros.
    Don’t keep trying to run it without the blower motor – the safety is doing its job by tripping out, but you will weaken it by constant resetting.
    HTH,
    Pidsley
    Sorry to be a dullard but where exactly is the fan motor and blades, i can see them from the top. I have checked wires all seem ok at first sight.
    #195031
    Looking at the top of the drum from the front, you have the heater duct running front to back and turning to the right. The fan motor should be mounted on the end of the ducting in the right rear corner. It should be identifiable by having a cooling fan on the end of it.
    Pidsley
    Hi I’ve just talen the back off. The heating duct runs along top centre front ot back. then dive 90degress downwards. There is a round part of teh duct mounted vertiucally on the back, this is sealed in cast metal. The belt runs from a motoe mounted on bottom of machine to the centre of the round bit on the duct. the duct end of this balet (i assume cenre spindle of encased does not turn. (the motor does), there is a rubber tube running from the rear of the heating duct to the vicenity of the powder tray.
    Are we talking about the same machine. Any ideas?
    Cheers
    #195033
    Pidsley
    Its def the fan thats knackered. the motot running the fan is fine. Is it an easy job the replcae fan? Its sealed all around with gasket, plus i need to take the drum flywheel off the back to get at it, a seriously sized allan key is required for this.
    #195034
    Pidsley wrote:I need to open up the heating duct to look at an extremely noisy fan. The fly wheel for thedrum is in the way. Can i easily remove these components?
    Will I need a new gasket for the heating duct once cover is removed.
    Any help gratefully received.
    #195035
    Pidsley
    Penguin there was no text with your last post, just a quote of me?
    #195036
    Correct – saved text from unneccessary second thread before deleting it.
    The blower motor is retained by two screws under the motor and four around the top of the condenser housing. I think you’ll need a 7mm socket for those ones. No need to actually remove the condenser housing.
    Fan should be p/no 268010200; spares@ukwhitegoods.co.uk will get you one.
