Re: Servis Easi Logic 1600 Washer – tripping electricity
To try and answer the question……
If you plug it in and switch on at the wall and it trips, the mains supprssor will be the culprit.
If the machine is plugged in and trips when you switch the actual appliance on, you need to do earth checks through the heater and motor. One of them is almost certainly the culprit.
