Servis Fridge – Acceptable temp fluctuations
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Servis Fridge – Acceptable temp fluctuations
  • #70722
    Russ h
    I have a spare fridge in the garage, Its in integrated under worktop fridge, I believe its a Servis M785.
    I want to check if its working, which it seems to be, but done a quick temp check with a temp probe mounting inside, and the temp fluctuates quite a bit. roughly by 4 -5 C
    I was wondering what is an acceptable fluctuation?
    Russ
    #378789
    Russ h
    Re: Servis Fridge – Acceptable temp fluctuations
    Bump
    #378790
    Dales-Electronic
    It should operate 1.5 degrees either side of the set point
    #378791
    Russ h
    Thank you for the reply.
    Would you say its accept then, its quite an old fridge I think
    #378792
    Dales-Electronic
    If you can get it to operate in the range +3C – +6/7C I wouldnt worry too much. The original spec for a domestic fridge was between 5 and 8C.
