Servis fridge freezer thermostat identification
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Servis fridge freezer thermostat identification
  • #72371
    Andy-C
    Just wondering if anyone can point me in the right direction to identify the thermostat for a Servis f/f?
    There doesn’t seem to be any makers plate on the f/f so I don’t know the model, I should think it is a mid 1990’s one.
    I’ve removed the faulty thermostat but the part number on it is very hard to read, it looks like A13 0374 C5??? (might be C5010). It has 3 terminals (+ earth) and the capillary tube is 850mm. I’ve found this one: 526012400 which is described as an A13 0374 but the pic does not match the one I have.
    Thanks for any advice
    #384350
    Andy-C
    Re: Servis fridge freezer thermostat identification
    Just an update to mention that the thermostat I have ‘looks’ like this one: 526013600
    #384351
    bryan-206
    Assuming your capillary goes into the fridge this item will be compatible. Or fit a vt9 or k59. But you will need to know your machines wiring for this
    Sent from mars
    #384352
    Andy-C
    bryan-206 wrote:Assuming your capillary goes into the fridge this item will be compatible. Or fit a vt9 or k59. But you will need to know your machines wiring for this
    OK, thanks. A VT9 is a lot cheaper, if it will do the job. The current thermostat terminals are marked 3,4 & 6 does the VT9 have the same numbering?
