Servis fridge freezer too cold M7684A
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Servis fridge freezer too cold M7684A
  • #26957
    sally
    my Servis fridge freezer M7684A is too cold, down to -2 sometimes at the bottom and back and is freezing all my food. I have bought an fitted a new thermometer from Servis but this has made no difference. Any ideas?
    #212051
    chuffer25
    Re: Servis fridge freezer too cold M7684A
    Could be tricky to diagnose without seeing it, but
    1/ have you pushed the long sensor fully into it’s tube?
    2/are you sure the wiring of the thermostat is correct?
    if the above are ok then you may have a weak compressor (it wlll run for long periods not able to reach the cut out point of the thermostat) or you may have lost some gas from the system, either of these is not good news, the compressor being expensive and the loss of gas may re-occur if the leak is from a component that is not replaceable.
    Hope this helps
    #212052
    Dales-Electronic
    Could you let me have the serial number of this appliance as there are 5 different versions. Soon as you let me have this I can have an in depth look at it for you. Cheers – Ian.
    #212053
    sally
    The serial number is 20004814656 038077046 03 01
    Thanks 🙂
    #212054
    Dales-Electronic
    According to my information this is a fridge freezer that uses a thermistor to sense the temperature (thermistor is an electronic component whose value changes with temperature) this is connected to an electronic control pcb that switches the cooling on as required. Now could you tell me what part you bought from Servis (and even better if you can indicate what part number it has) Just for your info your actual model number is – M7684A-UK.
    #212055
    jriant47
    Hi, not sure if this thread is still going to be alive but I’m having the same problem with the same model number. Can anyone help please? TIA
    *edit*
    My serial number is 20035113779-038077046-03 01
