Servis Fridge not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Servis Fridge not cooling
  • #9352
    Two days ago my Servis Fridge (not frost-free) defrosted all by itself.
    The fridge light is still working but the small freezer box is not icing up and the interior temperature will not rise above room temperature.
    The following information is on the back of the fridge.
    Aspera
    BP 1072Z
    221 CA07
    220/240V/50 H-Z
    Ester Oil 200cc
    R134a
    Barcode 261 421.
    Any suggestions, please?
    #133663
    Could be either a thermostat/module fault or compressor and/or related bits. 😕
    Very hard to tell with any more information with the description given.
    jongriffin
    Re: Servis Fridge not cooling
    irene
    can you hear the compressor/motor running
    #133665
    Thanks to kwatt and jongriffin for their replies.
    I cannot hear the compressor/motor running and the whole outside of the fridge, including the back, is at room temperature.
    #133666
    Further to my earlier posting today, I forgot to mention that it is difficult to turn the interior temperature dial.
    #133667
    Gavpo
    has the fridge plate at the back got silver pipes running behind it (heaters) if so a VT9 thermostat should do the job (if yours only used 2 wires and earth,use pins 4 & 6
    Gav
    #133668
    Gavpo,
    Thank you for your reply of 04/04/05.
    Sorry for not responding sooner.
    I have been away from home but have now returned to face the problem.
    The narrow pipes at the back of the fridge (outside) are black, not silver.
    Does this make a difference?
    Irene.
    #133669
    Dales-Electronic
    We are a Servis UK service company, to allow us all to give you further information would you kindly let us have the model and serial number. This will be on a small label – Model number will begin M7xxxx and the serial number will start 200xxxxxxxx. Thanks
    #133670
    To Dales-Electronic.
    Thank you for your reply.
    The model number is M7041. Below that is the number 99350461.
    There is no number beginning with 200.
    The only other numbers that I can see are as in my original posting.
    These include 221 CA07; 220/240V/50 H-Z and Barcode 261 421.
    Irene.
    #133671
    Dave_Conway
    M7041 is an under counter fridge with ice box.
    It sounds like the thermostat has gone, especially as it’s hard to turn.
    An easy enough and relatively inexpensive repair, check repairs@ and the directories for an engineer near you 😀
    #133672
    Dave,
    Thanks to you and everyone else for the help.
    Irene
