servis help
  • #49901
    crz
    Hi all I have a fault with my washing machine its a servis m6115
    The problem is it won’t drain I’ve checked filter and pipes all look ok so I ordered a new pump and fitted it but still no joy , it runs a program but when it gets to rinse it just flashes and won’t finish , any ideas ?
    Thanks Chris
    update: also my girlfriend has told me it blew the fuse and stopped working before I opened it up and checked pipes and fitted a new pump could it have blown the capacitor ?
    it still powers up and runs the program except for the draining part then it just flashes the start button green and wont continue ????
    #302696
    Bill
    Re: servis help
    Take a good hard look at the module! PULL THE PLUG FIRST
    Bill Ellis :scot:
    #302697
    crz
    what the PCB board at the front ? or the program control module at the rear ?
    I had a brief look at the one at the back which the two red wires from the pump run to and did not see any burnt out wires but I will have a closer inspection
    #302698
    Bill
    Re: servis help
    The one at the back, you proberly will not see anything!
    Bill Ellis :scot:
    #302699
    crz
    ok will have a look today is there anyway of testing the board itself or is it just a case of wire by wire check with a multi meter ?
    #302700
    crz
    Re: servis help
    pcb is fooked as shown on image anyone know a good company for a repair job as i cant find a replacement of that model for less than £100
    spec is :-
    Servis M6115 MINI SEL 1100 RPM 546031301 ELMARC 85 DX-65 SX
    #302701
    spanishwhite
    Re: servis help
    try EMW electronics (0115 9652118) i’ve used them before they are very good
    #302702
    crz
    Re: servis help
    thanks spanishwhite will give them ago and update how i get on next week
