Servis Larder Firdge Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Servis Larder Firdge This topic has 2 replies, 3 voices, and was last updated 19 years, 9 months ago by cornflakes. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts June 22, 2006 at 9:10 am #18642 cornflakesParticipant recently called to larder fridge Model M7750 inox proplem..ice forming on rear of cabinet. replaced thermostat with gen Servis spare part num SER526012802 same symptoms occuring..no change, fridge running all the time have revisited..check wiring and although confident i put back as original am i now thinking i may not have done? 2 points is part num CORRECT could stat be faulty thanks for any help Graham Leicestershire 😥 June 22, 2006 at 9:14 am #179749 gegsyParticipant Re: Servis Larder Firdge How far down does the ice go?? If its less than 2/3rds from top to bottom, it could be either low refrigerant or weak compressor. Greg June 22, 2006 at 9:30 am #179750 Dave_ConwayParticipant Re: Servis Larder Firdge The part number is correct but as Greg says, it sounds more like a system fault to be honest. Thermostat failure would normally result in frozen food. Dave. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
