What type of stat did you use? If it was the electronic type with a circuit board then chances are its a faulty one. If its a mechanical one, with individual wires could be wiring wrong. Apart from that not much else it could be. hope this helps
Mark 🙂
cornflakes wrote:recently visited servis larder fridge
cabinet freezing up on rear
replaced control stat with gen spare from service
problem not solved..unit still freezing up
any ideas
welcome
regards
Graham
Is it freezing up the hole of the back wall of the cabinet or just part of it
Iff its not freezing all the way across , low on gas or weak compressor
possible blokedge hope this helps loopey
Just a thought, sometimes the capillary gets stuck and doesnt go in far enough to sense the temp correctly. You could always put a universal type stat in and push it in further. I’ve done this before and no come backs. Sorry for the delay in replying
