servis m 3015 a module blown
Home Forums Public Support Forums Help And Support Washing Machine Help Forum servis m 3015 a module blown
  • #53869
    slyp98
    hi guys i have the above wash m/c with a burnt out electronic control module owner tells me it was tripping the rcd before it stopped working does anyone have any experience of replacing a module and all being ok afterwards its just that the module is a bit expensive over here , i have tried whitegoods spare parts but none is listed , thanks a bunch
    #317541
    Re: servis m 3015 a module blown
    There is usually another fault to cause the module to fail e.g. motor or heater failure. I would trace wires from the burnt section of the board to the likely culprit. A megger test would be useful for insulation tests between motor brush terminals and motor case, heater terminals and heater case etc.
    #317542
    slyp98
    cheers fidom will do
    #317543
    slyp98
    couldnt find anything wrong with motor or pump , she decided to splash out on a new machine thanks phidom
