Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Servis M0330s freezer problem
- This topic has 6 replies, 2 voices, and was last updated 19 years, 10 months ago by
paule.
June 16, 2006 at 5:53 pm #18533
paule
ParticipantAbout a month ago, my servis M0330s fridge stopped working. Following advice from this forum, I checked inside the freezer and (as expected) there was a large amount of ice built up behind the back panel. Melted this with a hairdryer, put it back together and all works fine.
Now the freezer’s stopped working properly – it’s stil pumping cold air out from the vents into the freezer compartment, but the temperature in the freezer compartment is only down to about -4 C rather than the -18 C or less I expected.
Anyone got any ideas what this could be?
Thanks,
PaulJune 16, 2006 at 9:08 pm #179345Dave_Conway
ParticipantRe: Servis M0330s freezer problem
It’s probably over-iced again which would indicate a defrost problem.
If it has then it will have a fault with either the defrost heater, defrost probe, thermostat or possibly the PCB which may require an engineer. The repairs@ link below should provide one if required 🙂
Power off if checking yourself please :zap:
June 17, 2006 at 8:17 am #179346paule
ParticipantCheers, I’ll check to see if it’s over iced later today.
June 19, 2006 at 12:11 am #179347paule
It was iced up somewhat again (not as bad as before) .
Would it be possible that these problems could be caused/made worse by there not being enought airflow to the back of the fridge freezer? It seems that it had been pushed back against the wall – could this cause the compressor to cut out and therefor the temperature to rise?
June 19, 2006 at 9:17 am #179348Dave_Conway
paule wrote:Would it be possible that these problems could be caused/made worse by there not being enought airflow to the back of the fridge freezer?
Possibly but it’s more likely there is an underlying problem with the defrost cycle to be honest but it’s worth a try 😉
June 19, 2006 at 12:42 pm #179349paule
It’s getting worse…. the freezer compartment is now running at a fairly stable fridge temperature, and the fridge is a slightly cooled cupboard.
The one thing I have noticed is that the main compressor unit is getting hot, but the heat is not circulating to the coils on the back of the unit.
Any idea how much callout charges are for this kind of job? Not wanting to spend loads only to hear that it needs to be sent to the scrapyard.
June 19, 2006 at 1:13 pm #179350Dave_Conway
paule wrote:Any idea how much callout charges are for this kind of job?
It varies quite a bit to be honest, between £30 and £50 as a rough guide. You can discuss that locally before comitting to a call of course 🙂
