Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Servis M0330s Lights flashing, making a ‘clicking noise’
- This topic has 6 replies, 4 voices, and was last updated 17 years, 4 months ago by
kellyLpool.
December 2, 2008 at 8:56 pm #41529
kellyLpool
ParticipantHi there, would appreciate any help or advice
I had my electricity meter replaced by Dataserve today. During the work the electricity was switched off. Engineer did advise to switch of the TV because the switch off might interfere with it, which I duly did.
However, upon the job been completed and not long after the engineer had gone I noticed a problem with my fridge freezer, Servis M0330s. It was like it had gone doo lally! All the 3 lights were flashing on off and it was making a ‘clicking’ noise like as if you were opening and closing it. But it still seems to freezing and refridgerating for the moment. The lights flashing and the clicking does seem to stop and start at different times.
Very annoyed that it now seems to be on the blink despite having no problems withi it for the past 4 years. I’d like some advice on what the problem possibly is? And any further advice on whether or not the works with the meter could’ve caused this. As I find it too much of a coincidence myself.
Sorry for the essay, Kelly
December 3, 2008 at 7:59 am #270487Dales-Electronic
ModeratorRe: Servis M0330s Lights flashing, making a ‘clicking noise’
Switch the appliance off, leave it off for 15 minutes and then switch it back on and see what you get.
December 3, 2008 at 8:32 am #270488kellyLpool
ParticipantRe: Servis M0330s Lights flashing, making a ‘clicking noise’
Will try switching off this morning.
But just an update, the freezer is no longer freezing. But refridgeration still seems ok. So I’m now doubtful switching off alone won’t work.
December 5, 2008 at 5:58 pm #270489trio
hi
pcb required
problem with one of the relaysDecember 20, 2008 at 8:10 am #270490sparkycpu
Hi kellylpool,
Did you get the problem with your f/f sorted?
if so could you tell me what the problem was as mine is doing the same!
December 20, 2008 at 11:18 am #270491trio
pcb needs replacing
December 31, 2008 at 2:50 pm #270492sparkycpu
had a service man out as under extended warranty and he said it had a blockage and a gas leak……
he cut the pipes and left the ff with no gas and unable to run said thats the law it had a leak and now have no ff until the warranty company sort out a replacement as servis has gone bust.
good job its cold outside perfect cheap fridge at the mo lol
