SERVIS M0330W
  • #33444
    fireblade14
    Recently the fridge/freezer appears to stop/start working intermittently. When the appliance is not working it is accompanied by the green power light flicking on and off. Also when you open the fridge door the light flicks on and off constantly about 1 per second. After a while the power light glows constantly and all is working fine. I have noticed that if you press the fast freeze button the flashing lights flash much faster. An engineer came out about six months ago as the fridge wasn’t working but the freezer was. It turned out to be ice build up preventing the cold air from the freezer being blown up to the fridge. All has been well since, until now! Any help please.
    #238740
    Dales-Electronic
    Re: SERVIS M0330W
    First off defrost the thing – that means switching it off for two days with the doors open and then restarting the unit. If that clears the problem you have a result, if not I would suggest you have a problem with the electronic module at the top.
