Servis M0330W fridge thermostat dial snapped
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Servis M0330W fridge thermostat dial snapped
  • #18177
    Axel2k6
    I have a Servis M0330W frost free F/F, serial # 20051413449-038077070-03.
    The fridge is freezing the food and the inside fridge thermostat control dial twists all the way round without stopping. Freezer is fine, compressor and fan both working.
    Upon opening and taking apart the thermostat housing, I found that the flexible plastic clamps on the end of the plastic rod which hold the control dial to the metal disc inside the thermostat body, have broken. (the metal disc which now falls off appeared to twist under the spring mechanism operated vent cover).
    It appears i need a new plastic rod part to the plastic control dial, but I’m unsure if another part has also broken off which I cannot see, or if I will be able to re connect the parts and line them up with the thermostat to enable them to work accurately?
    Would I be better off replacing the whole thermostat unit or just the plastic dial parts ?
    In either case where is the best place to order the parts please?
    The thermostat has the # D1072 414 on it, A.T.E.A.
    Any advise would be appreciated
    thank you
    #178019
    Dave_Conway
    Re: Servis M0330W fridge thermostat dial snapped
    The thermostat itself has a metal “D” shaped shaft so that should be OK and easy enough to re-align.
    I have no picture for this model, is there a chance you could email me a picture of the broken parts please and I’ll try an identify that way ? 🙂
    #178020
    Axel2k6
    Thanks Dave
    I’ve just mailed some pics for you.
    Ive realized how the parts go back together now. The flexible catches on the end of the grey control dial rod, when intact, must be square on two of their sides to stop them turning all the way round once sat in the receptical opening which has two straight sides, otherwise there is nothing to turn the receptical with?
    The metal receptical shaft is round so it must be the flexible plastic catches on the control dial rod’s end which take the strain on turning the dial, but they look as though they were thin and vulnerable hence they’ve snapped.
    The only thing i dont understand is how does the thermostat rod operates the vent cover? Does it expand/contract and pull on the wire ?
    Axel
    #178021
    Dave_Conway
    Axel2k6 wrote:I’ve just mailed some pics for you.
    Not got them yet, which can you send them to spares@ukwhitegoods.co.uk please 🙂
    Axel2k6 wrote:The only thing i dont understand is how does the thermostat rod operates the vent cover? Does it expand/contract and pull on the wire ?
    Basically yes, it expands and closes the vent stopping cold air entering the fridge.
    #178022
    Axel2k6
    Had mailed to dconway@…
    Just sent another to spares@…
    #178023
    Dave_Conway
    I just recieved the 1st ones 😀
    You need a new thermostat, I’ll reply to the email with prices etc a bit later 🙂
    #178024
    Axel2k6
    Thanks for the item # , price and for your help Dave
    Axel
    #178025
    Axel2k6
    Thanks Dave, received new thermostat control swiftly, was easily installed and fridge has been working perfectly.
    #178026
    Dave_Conway
    Great, thanks for letting me know :tup:
    Dave 😀
