Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Servis M3012W
- This topic has 13 replies, 5 voices, and was last updated 20 years, 7 months ago by
generaldomestics.
August 17, 2005 at 5:00 pm #11381
generaldomestics
Participant010077123-01
Machine appears dead.
Door does lock, mains power light on, live supply to both valves but no neutral so it wont fill.
Shared live supply to valves comes up from the module, separate neutrals from the timer.Gonna quote for a timer ❓ but not had this fault before. ❓
Used to get loads of module problems with these machines when I did work for GBdar.
My hunch on this one however is timer?Unless anyone has any alternative suggestions.
Ta.
Lee.August 17, 2005 at 5:03 pm #145140AMS
ParticipantRe: Servis M3012W
Sounds suspiciously like the module to me. Get the 546……… number off of the module label and give EMW a tinkle. Their new no is 0115 9652118.
August 17, 2005 at 5:07 pm #145141generaldomestics
Will do.
Thanking you.August 17, 2005 at 6:59 pm #145142Washman
You need 546…….. number 4 different modules listed for this model
Mike
August 17, 2005 at 7:38 pm #145143generaldomestics
I have serial no, can I use that to find correct part no for module?
August 17, 2005 at 8:40 pm #145144Dave_Conway
Yes, it should work in theory Lee, post it up and I’ll see what I can find out 🙂
August 18, 2005 at 7:12 am #145145generaldomestics
M3012W 516010301 010077123-01.
Thanks.
I had all the part finder software from GBdar but deleted it a few months ago, figured I didn’t need it?? 😳
LeeAugust 18, 2005 at 7:19 am #145146Martin
The part number of the correct module is stamped on the module (and begins with 546??????)
August 18, 2005 at 7:38 am #145147generaldomestics
I Know
August 18, 2005 at 7:54 am #145148Dave_Conway
None of those are the serial number Lee 🙁
516010301 is the timer part number but looking at the date differences on the Servis software it isn’t clear even if I had the serial number.
All the modules that fit it are of the DMPDC 1200 type but have different part numbers 😕
August 18, 2005 at 8:29 am #145149generaldomestics
Thanks for looking for me, I will have to go back and have a look.
cheers.
lee.August 19, 2005 at 8:09 am #145150generaldomestics
Customer provided serial no 995032488 ???
August 19, 2005 at 9:10 am #145151Dave_Conway
In that case it should be 546021600.
Assuming the information is correct from Servis of course 😉
August 19, 2005 at 10:41 am #145152Martin
When you check the module’s number, its best to megger the heater as well 😉
