Servis M301w
  • #45376
    IP
    Hi, i know this is a long shot.
    Does anyone out there have a wiring diagram for a servis m301w washing machine, as our customer has worked on it and stuffed up where the wires go !!!. Mainly all the ones to the stats and the heater.
    If anyone out there knows of anything to sort it out, drawings, scribbles on fag boxes, you name it, would be very helpful, as hes not interested in buying a new machine !!!!!!!!!
    IP
    #285494
    timdowning
    Re: Servis M301w
    Not sure if this matches your model????
    Two white wires to thermistor side. 2 grey wires to thermostat side. Grey from thermostat to heater.
    The thermostat/thermistor has 4 tags. Two tags are the normally closed thermostat side and the other two tags are the thermistor side. Ring them out two determine which is which, 0 ohms is the thermosat side.
    Hope this tallys with your machine.
    #285495
    IP
    HI, thanks for your reply but unfortunatly it has an extra what i think is an overload with 2 tags next to the thermostat/thermistor u described. The wire colours dont match but that might not be so important, i have all black wires with coloured connectors 3 white, 3 black and 2 red.
    thanks IP
    #285496
    Dales-Electronic
    Re: Servis M301w
    You have mail 💡
