Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Servis M3022 Backplate
- This topic has 10 replies, 5 voices, and was last updated 20 years, 9 months ago by
Dave_Conway.
June 29, 2005 at 5:00 pm #10418
Dave_Conway
ParticipantCould anyone confirm the part number please for the Servis M3022CW backplate as Connect come up with two options, both at over £100 trade !!! 😯
No info on this model on the Servis tech disk either for some reason 😕
Thanks in advance
June 29, 2005 at 5:15 pm #139831BobHope
ParticipantRe: Servis M3022 Backplate
HI Dave is it a /m or just plain cw on the end as there is to different product codes.
Cheers Bob.
June 29, 2005 at 5:31 pm #139832BobHope
Hi Dave,
product code 010077145
backplate and bearings complete part no 718006900
backplate only part no 716006301product code 010077170
backplate and bearings complete part no 718009500
backplate only part no 716008800
Cheers Bob.June 29, 2005 at 5:52 pm #139833Washman
Hi Dave
Some models are on the Servis DOMAR SATPRG disk and do not show up on the main disk
Washman
June 29, 2005 at 6:42 pm #139834Dave_Conway
Cheers chaps 😀
It just has CW on the end, any idea which one of those two product codes that is ?
We’ve not been to it yet but the customer’s description of “rubbling noise on spin” kind of gives the game away and I want to send the engineer spared up for the call.
Thanks again.
June 29, 2005 at 7:56 pm #139835admin
KeymasterRe: Servis M3022 Backplate
brg4646 and a tub seal dave…..works for us
Kevin
June 30, 2005 at 12:10 am #139836Dave_Conway
kheath wrote:brg4646 and a tub seal dave…..works for us
Ta Kev but if you think I’m going to let an engineer spend another 15/20 minutes knocking out bearings on a job that pays £38…… 😉
June 30, 2005 at 7:18 am #139837BobHope
Sorry about the confusion Dave,
Model no. M3022CW UK p/code 010077145 p/no 718006900
Model no. M3022CW/M UK p/code 010077170 p/no 718009500
hope that helps, and by the way Dave it is on the disks if you update them from the web site.
bloody nightmare Servis parts.
Cheers Bob.
June 30, 2005 at 8:19 am #139838kwatt
Dave_Conway wrote:Ta Kev but if you think I’m going to let an engineer spend another 15/20 minutes knocking out bearings on a job that pays £38…… 😉
And therin lies much of the the problem, its just not worth the extra labour if you even get paid for it, to be bothered to go down to that degree as you’ve already lost money on the call with it being a double visit usually.
Just ordering a backplate complete saves time, just the same as complete tubs, doors etc. and the overkill orders of motor, module and timer, although there is an element of training and familiarity there as well.
What always amazes me is that many a client can’t seem to understand that time is money, unless it’s their time of course, and that if an engineer needs two or three slots (time wise) allocated to one call then that call just cost you two or three jobs that you could have been doing. But not only that, for such repairs it’s usually cost you an initial call to inspect and order spares as well so one call just took up the same time as three or four calls so you lost those calls that you would have otherwise been able to do, or the engineers end up overbooked and you lost financially from it too. Were we charging by the hour I could afford to employ another engineer to do allow the engineers not to be stressed out and have more time to do things a bit better, but that I reckon should be common sense.
However the fact of the matter is that contract customers often force this attitude and also created and bred this culture of just replacing spares like this, as well as the “overkill” jobs, simply because there’s not enough profit to support any other way of working. Then they come on screaming that you’re using too many spares!
Maybe some people should read this post very carefully and take a long hard look at what they’re doing.
June 30, 2005 at 12:29 pm #139839Dave_Conway
BobHope wrote:Model no. M3022CW UK p/code 010077145 p/no 718006900
Interesting – 718006900 Connect price £101 with no alternative.
I phoned GBDar to check, part number supersedes to 718004200 Connect price £42.00 and in stock.
Work that one out then 😉
Thanks for your help guys 😀
June 30, 2005 at 6:11 pm #139840admin
yes dave but if connect told you that it had supperseded then they would’nt sell the £100 parts that they bought in under the superseded part number..not that i’m been synicle or scepticle at all.
bryan
