Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Servis M3022/M
- This topic has 17 replies, 7 voices, and was last updated 20 years, 10 months ago by
Phidom.
June 9, 2005 at 7:42 pm #10039
ParticipantFitted new bearing kit and door seal to this machine and now the drum is squeaking as it rubs the edge of the seal. The bearing kit and seal were pattern (Invicta) parts so I suppose the seal may differ slightly from the original. The drum shaft seemed to be a tight fit in the bearings so it is possible that it has not pulled through fully but I don’t want to tighten the nut too much in case it breaks the spindle thread. I had a job getting the spindle out of the old bearings so I suppose this is normally tight. I have had this problem once or twice before with new door seals and have sometimes resorted to removing the seal and cutting off excess rubber. Is there a trade secret for dealing with intransigent door seals? 😕
June 9, 2005 at 7:59 pm #138003admin
KeymasterRe: Servis M3022/M
I find the inner bearing surface of the shaft and the new bearing can be a very tight interference fit, causing the difficulty in mating the two parts.
I usually wire wool the shaft ( not the water seal collar)before fitting to eliminate the problem. Don’t have the problem with new shafts, only when the existing is used.
Kevin
June 10, 2005 at 5:40 pm #138004Dales-Electronic
ModeratorRe: Servis M3022/M
Hi this door seal catching is quite common even with the genuine door seal – I usually run the machine on spin with no water in and let the edge of the tub chop off the excess. On the subject of tight shafts if you get stuck the spider is available as a seperate item – although its not advertised by Servis as being avail. If you want further info PM me.
June 10, 2005 at 8:06 pm #138005charlieboy
ParticipantRe: Servis M3022/M
its the back half tub seal ….put a new one on they come in differant thicknesses and cose its new its a bit thicker and will bring the drum back slightly away from the door rubber…..dont wire wool nothing you will have problems……..i spose it pays to do work other than zanussi mr kheath…lol…………………..
June 10, 2005 at 9:01 pm #138006Phidom
Once I’d done a rinse & spin it seemed free enough so the machine is now back with the customer. It was not down to the bearing seal thickness as the bronze bush did not fully penetrate the seal. The shaft surfaces looked very good but the rear bearing was a bit loose in its housing so I stuck it in with loctite.
June 10, 2005 at 9:16 pm #138007charlieboy
hi no not the bearing seal ….i meant the big black half tub seal at the back ..but glad you sorted it ..have a nice one…..
June 10, 2005 at 9:25 pm #138008eastlmark
charlieboy wrote:its the back half tub seal ….put a new one on they come in differant thicknesses and cose its new its a bit thicker and will bring the drum back slightly away from the door rubber…..dont wire wool nothing you will have problems……..i spose it pays to do work other than zanussi mr kheath…lol…………………..
Hey Charlieboy, cool it a bit. Kevin was only suggesting cleaning up the drum shaft, removing rust, burrs, pitts etc. I am sure you agree that that is normal practice, personally I use emery cloth but what the heck.
As for this problem, i usually remove the backplate again and re-fit it as Its often an alighnment problem, common on Philco’s in the past.June 10, 2005 at 9:27 pm #138009charlieboy
was only messing……have a nice one ……cheers….
June 11, 2005 at 7:24 am #138010Phidom
Sorry, I misread the bit about the tub seal. 😳 I never bother renewing these, i just use silicone on the old one but if anything that should bring the drum further back rather than forward, although most of it gets squeezed out anyway.
June 11, 2005 at 11:12 am #138011Bill
Since I do a lot of work for servis I was interested on what was being said, please always use a new seal and pull the inner drum right back by putting the pulley retaining nut on about 3-4 turns and slip the spanner edge between , making sure that the drum is all the way back this will stop any damage to the door seal. I also use a little silicone grease on the bearing seal that stops any sqealling.
Bill
June 11, 2005 at 5:57 pm #138012charlieboy
very good…….
June 11, 2005 at 8:56 pm #138013Phidom
Hi Bill, do you find the Servis work pays enough as I gather they struggle to get free-lance repairers?
June 12, 2005 at 10:20 am #138014Bill
Due to the quantity I get it gives me a very fat cheque at the end of each month 😀 Bill
June 12, 2005 at 1:02 pm #138015pup
bill
do you work for servis or g.b darJune 12, 2005 at 7:08 pm #138016charlieboy
pup what area do you work….i work for them..just as a filler …..its easy work…i only do about 10 jobs a week in between my own jobs . i dont seem to get any probs with them……cheque always here the 1st of the month…
