Servis M3024/M Thermostat
  • #26536
    nelson
    Hiya chaps, can anybody help, I am trying to get a thermostat for a servis M3024/M (serial no. 20015103223). When I enquired with my local parts supplier, the part he was suggesting was different, he said if I got the part numbers off the stat, then he could order it for me. But my stat has been on fire (belt snapped obvoiusly hit the stat it has shorted out and made a bit of a mess of its self) so I cant get anything off it.
    It is the 40deg/60deg stat.
    Also this may be pushing it but if anyone has a wiring diagram coz it has made a bit of a mess of the nearby wiring.
    Thanks 🙂
    #210490
    Dales-Electronic
    Re: Servis M3024/M Thermostat
    Just check the serial number would you that one comes up as a tumble dryer m2001w.
    #210491
    Washman
    Its a DOMAR made washer dryer model and serial no’s match up
    picture shows two
    fixed stat part no 526001300
    thermo resistance part no 526011900
    Mike
    #210492
    nelson
    I think I had better call back out and double check the serial no. because I am sure it is just a washing machine. I’ll get back to you. cheers 😕
    #210493
    Washman
    Sorry you are right, it is a washer only the stat no is correct
    Mike
    #210494
    nelson
    Hi mike,
    Thanks for that, I don’t suppose anyone can help me with a wiring diagram for this machine? like I said the wiring is in a bit of a mess.
    Cheers
    Neil
