Well you must be saying Not again,Not another Servis.
Have this machine witht the sole motor.Only problem is that I does not do a full spin.At spin cycle it just goes around like wash spin.The module is ok (beleive it or not) because I had another machine to test it.Took the belt out in case exessive force, even put the motor in another M3025 and still no joy.
I have checked the contiunity of the motor wiring seems ok.Could it be the tacho.It is showing a resistance of around 180 ohms whoch is pretty much same as the working motor that I have.
Then what could it be?
Thanks Guys
