Servis M3103A washing machine just spins :0(
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Servis M3103A washing machine just spins :0(
  • #32732
    tideeetraxxx
    Hello one and all :0)
    this is my 1st time in using this forum so just like to say a big hello first on all.
    Okay heres my problem if anyone can help me.
    A few days ago my machine was not pumping out the water from the unit and after a good clean out (the usuall stuff from kids pockets blocking the piping) the machine run for a short while normally before going into a fast spin cycle on any click position on the program dial. Then there was a small bang noise and the unit went off..
    After inspecting the machine i found that the small pcb on the rear bottom side of machine had a broken soldier join where the wiring loom plugs onto it … this was repaired and there is now power to unit (pumps water in and out)
    But to my frustration i have the same problem that the machine just seems to keep on wanting to go into spin cycle no matter where the program dial is clicked to :0(
    Any ideas on this please ??
    As you can understand that with 5 children and christmas just around the corner i need to resolve the problem asap
    many thanks in advance to all that may offer help
    Az
    #236216
    Re: Servis M3103A washing machine just spins :0(
    Sounds like a speed control issue between the motor’s tacho unit and the control PCB. So the motor and its Tacho needs careful inspection together with the connector blocks to the PCB. The most common problem may turn out to be a faulty PCB too? 🙁
    #236217
    Washman
    Its most likely a PCB fault.
