just replaced the drum bearings on the washing machine….all went fine with no problems until I put the drum back in the housing and tried to refit the rubber seal and clamp ring!
I ended up glueing the rubber seal into the clamp ring, but the clamp bolt is a good inch too short so you can’t start pulling the clamp up. The only way I can see to do it is to buy a 4″ length of M8 studding and use that to replace the original clamp bolt.
Anyone else done this?
John
