Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Servis M320
- This topic has 5 replies, 5 voices, and was last updated 17 years, 4 months ago by
simonb.
November 27, 2008 at 11:58 pm #41406
simonb
ParticipantCustomer reporting spin fault, on test it went into full spin with no load test, customer says failing to go into fast spin.
now im stuck normally when no drum action its circuit board resistor failure, or failing iv had capacitor failure on these models before now, next comes the induction motor in third place?
Whats it likley to be as it did spin with no load? iv not tested it with full load as yet and customer says its failed with part loads and full loads.
also board number is remco 560101
with 20uf capjust priced parts for board and cap and come through at around £20 so it viable to change both as long as its not likely to be the motor!!
the board is listed on qualtex as SER546001402
and on board on machine is 560101? will it fit?thanks again simon
November 28, 2008 at 12:45 am #270055Penguin45
ParticipantRe: SERVICE M320
546002102 is the same beastie – £14 from Masterpart. Go for it.
November 28, 2008 at 7:39 pm #270056leavemetogetonwithit
I’m surprised you didn’t test the capacitor. Worth getting a meter with uF scale on, they’re cheap enough now.
Mike.November 29, 2008 at 12:20 am #270057alro
Make sure belt is tight
alroNovember 29, 2008 at 1:07 am #270058simonb
yes your right about keeping a test meter for capacitors its frustrating and it makes all the difference at times, i changed both board and cap in end and running fine now.
i need an auto ranging test meter that powers down if left on, as well as a torch that does the same, one that can bounce as well and also water proof and leads that can withstand being wrapped around the rest of my tools if it makes plenty of beeping noises the customers like them sort, maybe have a high voltage stun feature to disarm annoying customers wouldent go a miss, 😆
“oh you want to know how long iv been doing this job?”, just come here and hold my meggar test leads while i have a think!”, the best answer has got to be for this one is “its my first day” :rolls:November 29, 2008 at 1:10 am #270059Lawrence
if it has a long white timer its that ,otherwise its a 22uf capacitor,if its the module you get NDA
