Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › servis m3510 wont spin ? only 1 year old !!!!!!!!!!!
- This topic has 31 replies, 9 voices, and was last updated 21 years, 7 months ago by
admin.
September 3, 2004 at 7:34 am #116009
KeymasterPenguin, normally I’d agree with you and, on many other brands you’d be spot on but after seeing a few hundred Servis machines as warranty calls you get to know that water = naffed board 99.9{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time.
The only reason I know about the resistor trick is that Servis ran out of stock of them for a while and that seemed to cure some, if not all, but for the few pence it’s worth a go IMO.
From what Stevie originally said about the Y-hose leaking (a not uncommon fault with them BTW) often the water will track to the lowest point at the rear of the drum, drip onto the motor commutator and BLAM! Just what damage it does depends on the severity of the leak obviously but it’s not normally good news as it often dead shorts the comm and takes the module with it, sometimes the harness as well as the edge connectors just about disintegrate on some of them.
Since the usual prices for a motor exceed the purchase price of the appliance let alone adding the £80 ish module, every one of them is usually a write-off!
Due the low cost of the appliance, I assume, there is no splash shielding on either the motor or the harness, the module is housed in a box but that’s not watertight by any standard. Water, electricity and electronics rarely mix well together. 😉
September 3, 2004 at 8:27 am #116010Penguin45
ParticipantYep, Ken, agree with every word!
September 3, 2004 at 10:05 am #116011admin
KeymasterRe: servis m3510 wont spin ? only 1 year old !!!!!!!!!!!
hi k I’m going to try the resistor trick mate,
where can i get them from
cheers
stevie 🙄September 3, 2004 at 10:14 am #116012kwatt
KeymasterIf I recall correctly we had to get them from RS Components but it was a while ago. 😕
September 3, 2004 at 7:28 pm #116013admin
had a look on the web at rs and maplins websites but couldnt find any resistors that look like the ones on the module, are these a specific type of resistor
what is it i ask for k 🙄 🙄 🙄
cheers
stevie
ps thanks for your adviseSeptember 3, 2004 at 7:58 pm #116014Penguin45
ParticipantRS p/no 206 1186 6k8 7w wirewound ceramic resistor.
Luck,
Penguin45.September 3, 2004 at 8:01 pm #116015kwatt
KeymasterEhm, I think we had to do some digging but I asked a collegue and he’s positive that RS did list them in their catalouge. Sorry, it’s been at least 18 months or more since I last looked at them as we will replace the failed component in accordance with the manufacturer’s instruction and that generally means not going to component level.
September 3, 2004 at 8:25 pm #116016smbodywork
ParticipantRe: servis m3510 wont spin ? only 1 year old !!!!!!!!!!!
just had a look at the rs website penguin and the one you mentioned dosent look anything like it will it still do the same job 🙄 🙄 🙄
September 3, 2004 at 11:08 pm #116017Penguin45
ParticipantIf we are talking about the 2 large white “ballast” resistors on the 546 type digital control board these should be a suitable replacement.
September 4, 2004 at 8:48 pm #116018smbodywork
ParticipantPenguin45 wrote:If we are talking about the 2 large white “ballast” resistors on the 546 type digital control board these should be a suitable replacement.
cheers mate took your advise and ordered the resistors from rs
they’re only a tenner delivered, so ive nothing to lose if they dont cure the problemthanks again
and to all who have replied to this thread, your talents are wasted on whitegoods you should all work for N.A.S.A 😆 😆 😆
CHEERS
September 4, 2004 at 8:53 pm #116019Penguin45
ParticipantNASA buys what we don’t drink to use as rocket propellant………
Let us know how you get on,
Penguin45.September 4, 2004 at 9:00 pm #116020smbodywork
rocket propellant …….. mmm if the resistors dont work i might try a pint of that in the machine to make it bl***y spin
will let you know if it blows up the house !!!!
cheersSeptember 29, 2004 at 7:31 pm #116021admin
My washing machine is a blucher inox M8144 and the module is exactly the same.
I have the following symptoms:
When it should spin it won’t get up to speed. It just kinda goes back and forth at a lower speed.Now What I would like to ask is:
Is this indeed what you saw on the machine you were working on and did replacing the resistor do the trick.
Hope you can help
Jeroen Paes
September 29, 2004 at 9:17 pm #116022Penguin45
ParticipantHi Jeroen,
I’m afraid to say we never did find out how this ended. The general concensus was that the module was the most likely problem as with so many of these Merloni built machines.There are some good points to check in this thread to give you some guidance, but if you’re not sure get professional help.
Penguin45.November 17, 2004 at 12:15 pm #116023silverfox
ParticipantI have a problem with a friends machine purchased in Holland. Following this thread it looks like I have the same module quoted earlier. Apparently during a spin cycle the machine blew up and caused the electrical circuit in the house to trip out. I have examined the board and it looks like one of the relays has burnt out causing the small resistor R64 to burn onto the L1 coil. Basically it is knackered, but I was wondering how much a replacement would cost and where would I get one ?
