been to check this dishwasher today. owner said no heat but after checking stats and heater i found no problem. i spoted a fault with the powder door. it fails to open when maching is in use. could these faults be related machine is fairly new. any clues ? i got model and serial numbers here. im going back saturday to check after owner has refilled salt container then maybe strip door to check timer and connections
Hi Paul,
Washing without powder, even with heat, ain’t going to clean the pots. Has the customer opened the door to check in the cycle? Bet she hasn’t…. The number of people who associate heat with cleaning is amazing – you’re probably on the right lines withe the soap box!
the lady did say after wash items inside were still stone cold and loads of water still inside unlike her friends machine. would the powder door not opening stop the heater from working ?
Wouldn’t have thought so Paul…… Usual process of elemination I suspect. Check for a re-set stat though – had a few problems with them because of water levels…….
checked stats heater pumps solonoids under this dishwasher even checked for broken wiring only thing im unsure of is a level switch on side of the heater. but powder door still faulty. ill check all parts in there first then post back
