Servis M4705W
  • #46876
    flutie
    This dishwasher seems to be wanting to continually empty, even though it is empty, if I put water in the bottom of the machine, it does drain away properly but never stops pumping. Th lights did flash on/off, but now no lights are illuminated. The on/off switch has no effect, pump operates even if its switched off, the only way I can stop it is to pull the plug! Looking to me like a new machine is needed!
    #291167
    Re: Servis M4705W
    Flood protection operating? There’s a float switch mechanism in the tray under the machine which will run the drain pump regardless of the programming.
    Power off, drain off, find the leak.
    flutie
    Re: Servis M4705W
    thanks very much for the information, do you know of anywhere I can download a manual from, the user guide that came with the machine is no good at all with respect to troubleshooting.
    #291169
    Re: Servis M4705W
    There’s no such beast as a service manual………. 🙁
