Servis M6000-1W washing machine refuses to start
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Servis M6000-1W washing machine refuses to start
  • #74560
    zanussi_hoover2
    Hello,
    I have a servis M6000-1W washing machine, I have had it since 2007 and recently it has refused to start.
    I have had someone out to look at it and he told me that some connections on the PCB (the one which sits behind the buttons) had corroded and that one of the buttons was wedged in to the PCB (put it like this, it looked sort of melted in to the PCB) so he changed it.
    When the old PCB was in, the machine would start, and you could hear a clicking noise from the machine and then the light behind the start button would go out and the machines door would still remian locked, now, the new PCB does EXACTLY the same, there is no change in the machine what so ever 🙁
    Any suggestions on what I could do myself to try and get it running?
    #392005
    billtec
    Re: Servis M6000-1W washing machine refuses to start
    hi,had one of them machines in for repair ,was doing the same thing,relays clicking etc,so suspected motor,brushes were as new and all looked good,tested motor ,but no go ,so stripped it down,and found a fuseable link inside had gone o/c, found a spare to fit ,and machine started up ok ,and been ok since,hope this helps thanks.
    #392006
    zanussi_hoover2
    Hey 🙂
    thanks, what part was it that was fused and where was it located?
    thanks 🙂
    #392007
    Embedded in the motor stator windings.
    #392008
    zanussi_hoover2
    how can I get to the part, what part is it and is it easy to change or will I need to get my local washer man to help with it?
    #392009
    zanussi_hoover2
    also, how much is the part in question? and how do I get into the motor?
