servis m6002 going into spin Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › servis m6002 going into spin This topic has 4 replies, 5 voices, and was last updated 18 years, 7 months ago by machineman. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts September 7, 2007 at 1:58 pm #30369 machinemanParticipant hello, I have a M6002 going into spin even when the machine is in the stop position. Ne ideas? It has to be board I’m thinking Cheers September 7, 2007 at 2:27 pm #226948 timdowningParticipant Re: servis m6002 going into spin Yes it is the board at fault. Insulation test the motor while you are at it. If motor ok just change the board. (Had the same fault last week on the same model) September 7, 2007 at 2:30 pm #226949 Owain84Participant Re: servis m6002 going into spin brilliant Cheers! September 7, 2007 at 4:00 pm #226950 WashmanParticipant Re: servis m6002 going into spin Hi Two common faults on these 1– machine goes into spin when switched on and 2–machine totaly dead both mean new main boards. Mike September 7, 2007 at 6:48 pm #226951 bazza500Participant Re: servis m6002 going into spin On some Servis machines when the machine is totally dead it is resistor R1 on the board. Replace it with a 8 to 47 ohm resistor of at least 2 watts and this will fix it. Could be the difference between writing it off or getting the repair. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
