Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Servis M6002 manual
- This topic has 5 replies, 4 voices, and was last updated 16 years, 1 month ago by
JeffC.
February 20, 2010 at 5:29 pm #52663
JeffC
ParticipantHi,
I’m hoping someone here can help me locate or provide a manual for a a Servis M6002 washing machine. I’ve looked at pretty much every possible link that either said or suggested they could provide a copy but have had no joy.
If anyone here can help me it would be greatly appreciated.
Best regards
JeffFebruary 20, 2010 at 5:32 pm #312657timdowning
ParticipantRe: Servis M6002 manual
Is there something specific you want to know or clarify with the machine?
February 20, 2010 at 5:36 pm #312658JeffC
Idealy I’d like to know what the 4 buttons to the left of the dial are for and which compartments are used for which wash cycles.
June 17, 2010 at 1:46 pm #312659Loubylou2000
Did you get any respons on this? I just got the same model and manual covers all but the use of buttons! Mine wont start, just flashes a green light at me.
June 17, 2010 at 1:54 pm #312660timdowning
This can be something as simple as the door not being closed properly. Or the start button has been pressed to hard, and over a period of time the start switch has come off or out of allignment.
Open and close the door a few times. And with the palm of your hand push the handle flush with the door itself.
March 1, 2011 at 8:55 pm #312661nig30
Loubylou2000 wrote:.. Mine wont start, just flashes a green light at me.
Mine used to do the same. Washer started occasionally but would usually just flash the LED behind the start/stop button.
Noticed there was no tactile feel to the start/stop button. Removed PCB with buttons on and replaced the tactile switch with a new one. Checked original switch with multimeter and switching action seemed OK. Got new one with a longer plunger and filed down to match original profile. It’s a fairly common foot-print part. Seems like the diaphragm within the original switch had failed so no positive clicking action when pressed. Re-assembled taking care to align rubber button covers. Note the start/stop switch is recessed with respect to the other 3 buttons to the left.
After replacing the washer has always started first time of pressing start button.
Hope this helps someone.
